Help!!
Old Jan 30, 2008 | 03:15 PM
Birdman305's Avatar
Default Help!!
my oil pressure goes down after my car warms up, i put it on the computer and it says my oil pressure is good, the car drives fine, no overheating, so what should i do?
Old Jan 30, 2008 | 06:31 PM
jester1614's Avatar
oil pressure will naturally go down as the engine warms up due to the oil thinning.... at idle mine runs approx 16-20 lbs and thats decent as long as when it revs the oil pressure rises....from what i have read the specs are 10lbs of oil pressure for every 1000 rpm
Old Jan 30, 2008 | 07:33 PM
cruzin94's Avatar
yea my oil shows pretty low to, looks around 10lbs when idling after ive been driving for a while but as long as it goes up to match ur rpms your fine
Old Jan 30, 2008 | 08:53 PM
Birdman305's Avatar
Okay try 0!! When i stop the check gauge light comes on but when im driving the pressure is up to about 20-25lbs... like i said no overheating or anything like that
Old Jan 30, 2008 | 09:05 PM
Razor_Blade's Avatar
I had the same problem with my factory guage until I broke the sending unit while installing headers. The machanical guage that I replaced it with shows plenty of pressure.
