Leaking Oil Pan On 95 Camaro LS1 PLEASE HELP
if it is the oil pan gasket you have to drop the pan and its a big pain I've been a mechanic for several years and even I might take my car to the shop for this depending on how much its leaking haha and I just put heads on my car if that tells you anything.
Dont remove the maf screen that maf is good for up to 500 hp.
1) Let someone kick you in the nuts
2) Pay someone else to drop it for you
In all seriousness, you have to raise the motor a touch to get the pan off. I can't remember if I had to take the motor mounts completely off or not. Regardless, it sucks.
The reason Im asking is because the "mechanic" that worked on my car for the previous owner replaced the timing chain and just like the OP I have some issues with oil leaking from the front of the motor. The reason Im concerned about the oil pan gasket being torn is because there's A LOT of RTV or some kind of sealant all over the bottom of the timing chain cover where it meets the oil pan.
To the OP:
You said you can hear lifter tap...are you sure its not just a rocker arm? LT1's have pretty noisy rocker arms...so it's just a thought. Also since its the DS head you can easily check to make sure the rocker arms aren't too loose.
Also here's a link to a site that provides a lot of helpful info for doing work on LT1's. It'll probably be very useful to you.
http://shbox.com/1/4th_gen_tech1.html
About the lifter noise? If infact it is the rocker arm, which i am now thinking it is, Does aynone know the specs on the intake and exhaust? What feeler guage to use? Thanks you guys are awsome and I love this site. Thanks again.
