389 information
Old Feb 2, 2008 | 09:15 PM
ATAY383's Avatar
Arrow 389 information
Has anyone done a LT1 389 stroker if so can u guys give me some specs on tq and hp and is it better than a 383. Thanks.
Old Feb 2, 2008 | 10:07 PM
kgkern01's Avatar
Are you referring to a 3.8" stroke 4.03 bore (a 388) or 3.8 stroke 4.04 bore (390)? I would think it would be slightly more torque than a 383 and less worry of breaking the water jacket as with a 396. That is actually what I plan on doing in a few years once I need a rebuild.
Old Feb 2, 2008 | 10:40 PM
94'BLKBRD's Avatar
just stick with a 383
Old Feb 2, 2008 | 11:41 PM
ATAY383's Avatar
bored over 40
Old Feb 3, 2008 | 12:48 AM
engineermike's Avatar
Mine is 3.75 x 4.060, which makes it 388.4 cid. The only reason I did it is because my 4-bolt converted, clearanced, zero-decked, and ported block needed a bore job and was already .030 over. You'll likely never see a difference in hp and torque from the extra 5 cid. I'd say about 7 ft-lb and 5 hp.
Old Feb 3, 2008 | 01:03 AM
Built LT1's Avatar
+1
There's a multitude of reasons to keep the stroke at 3.75.
Mine's currently .060 over and comes out to 388 cubes.
Old Feb 3, 2008 | 10:46 AM
ATAY383's Avatar
see i have to do it more than 30 cause my cam is flat and it put scratches in the cylinder walls and my friend told me to do a 389 but im just wondering if its worth doing it or will it **** up again.
