ASM monoblade question
Old Feb 6, 2008 | 03:28 PM
sheikss's Avatar
Default ASM monoblade question
Tryin a few things to help the numbers alittle when I go to get it tuned again. Currently I have a BBK 58mm on a 383 with LE2 heads and a LE3.2 cam along with all the bolt ons. What gains could I aspect to see going to the monoblade? I know the asm 58 flows 1050 cfm and the mono flows 1300 cfm if that helps out?
Old Feb 6, 2008 | 04:03 PM
O Holy P's Avatar
You won't see much if anything. It will look prettier though. A 52mm TB is technically all you need untill you surpass about 700rwhp.
P
Old Feb 6, 2008 | 04:09 PM
Stroked96Bowtie's Avatar
I had a buddy that had a monoblade and had a hard time getting the car to idle right...monoblade is probably better kept on drag cars..if thats what your shooting for then cool. Ive got the AS&M 58mm sitting here waiting to go on so we'll see how it works out in the next month or so.
All that cfm is great you just need the right cam, heads, exhaust to move it. LE did your H/C setup and should be able to offer some good insight also.
