rear main seal
Old Feb 8, 2008 | 08:51 AM
camaro-94-z28's Avatar
Default rear main seal
2marrow i plan on looking under my car to see were the oil is coming from. im 90% sure its the rear main seal. how hard is it to replace? i looked at a thread on how to remove the trans. but in general what problems did u have replacing the gasket? any recomendations or tips?
Old Feb 8, 2008 | 10:16 AM
blackz6sp's Avatar
It's no big deal, just a seal Ive used a couple screws to pull it out that worked alright.
Old Feb 8, 2008 | 12:42 PM
RBE17's Avatar
Replacing it is a piece of cake. You do have to remove the trans. I've never installed one w/o the tool GM makes for installing it. Your local parts store might have one you can rent.
Old Feb 8, 2008 | 02:56 PM
C5042081's Avatar
also check out the oil pressure sensor, oil pan, and intake manifold for other possible oil leaks.
Old Feb 8, 2008 | 03:08 PM
nighthawk15's Avatar
When I installed mine I just put the old seal on top of it and tapped it in with a small hammer. A tool probably isn't a bad idea though.
Old Feb 8, 2008 | 04:57 PM
CamaroRacing12's Avatar
i think i am going to replace mine also when i pull my trans for its rebuild
