opti vaccum lines??
Old Feb 11, 2008 | 03:28 PM
mean94lt1's Avatar
Default opti vaccum lines??
does anyone have any pics or detailed desc of how to hook up the vaccuum lines on the opti i did the conversion to a vented opti on my 94 z and am not sure where these lines go??
Old Feb 11, 2008 | 04:36 PM
Smokinlt1's Avatar
http://shbox.com/ci/opti_vent.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
http://shbox.com/1/opti_vacuum_conn.jpg
Those are what I went by.
Old Feb 11, 2008 | 07:21 PM
mean94lt1's Avatar
ok thanks
Old Feb 11, 2008 | 07:58 PM
LT1Falcon's Avatar
just did it the other day actually. one line runs to the driver side of the intake (vacuum) and the other plugs into the bottom of your intake elbow. it was very simple for me
Old Mar 21, 2008 | 10:37 AM
mean94lt1's Avatar
anyone else have any pics i converted mine and the vaccum lines are diff on my car since its a 94 those pics are helpful but my pcv is where the opti vaccum line is supposed tto go anyone?
Old Mar 21, 2008 | 10:44 AM
porksoda's Avatar
I used the little EGR nipple piece right above the PCV valve since I deleted EGR. If you have EGR then you need a "T" fitting to split it to the EGR and the opti.
Old Mar 21, 2008 | 11:02 AM
mean94lt1's Avatar
ok which line did you run to that one the one that comes off the cap or the smaller one in the dist part?
Old Mar 21, 2008 | 11:07 AM
porksoda's Avatar
You want the one in the cap routed to the elbow and the other hose to the vacuum side.
Old Mar 21, 2008 | 11:12 AM
mean94lt1's Avatar
those diagrams show the one in the cap going to the vaccum on the intake and the one in the opti going to the elbow
Old Mar 21, 2008 | 11:13 AM
porksoda's Avatar
I may have had it backwards? I didn't even check the links.
Old Mar 21, 2008 | 11:15 AM
mean94lt1's Avatar
this one shows the one in the cap going to theintake manifold im just trying to figure this out cuz the msd opti i put on it is making a weird noise i didnt know if it was cuz i didnt have the vaccuum lines hooked up right if thats not it it has to come back off damn it
