93 guys got ?
Old Feb 12, 2008 | 12:32 AM
LTwonZ's Avatar
Default 93 guys got ?
Have any of you got changed your "huge" oil pressure sending unit for one of the smaller 94+ units? With the longtubes the big sending is a pain and i'm thinking of trying to swap to a smaller one.
Old Feb 12, 2008 | 03:55 AM
Schweet97Z's Avatar
93's are a PITA! im in the process of putting on back together now. EVERYTHING is different. But non the less the sensor has to be there.
Old Feb 12, 2008 | 11:49 AM
Pampered-Z's Avatar
Shut up Harold! The 93s have everything in the right place, it's all the other years that are odd!
It's a standard thread, you could go to a hardware store and get a 1"-2" straight and 90 degree elbow and relocate the unit so it's out of the way. There is also a fitting in the top of the block behind the EGR that you MAY be able to use as well with some type of adapter.
Old Feb 12, 2008 | 12:40 PM
thebufenator's Avatar
I ended up going with a newer unti, but its got a different threading.
its threaded into the top of the block, where the newer ones go....
Old Feb 12, 2008 | 01:13 PM
Schweet97Z's Avatar
LOL!
thebufenator - did you have to extend the wiring harness at all? get a different plug? thats good to know
Old Feb 12, 2008 | 04:25 PM
Formula350's Avatar
Bet you could make a remote mount with a hose and extend the wiring
I prefer where 93s is. Easy to swap out.
Old Feb 12, 2008 | 09:13 PM
street demon2k3's Avatar
The plug on the back of the block can be relocated to the existing thread and just swap the location. I just got a 90 degree elbow at a plumbing store, never had problems with it ever. I dont even notice it unless I need to pull the motor again..lol
Old Feb 12, 2008 | 09:35 PM
Speed Density's Avatar
hashtagBMW
Its not that big, lol.
Just 90* it forward and its fine. Ive been doing that for years on both mine and a buddys 93'.
Tony.
Old Feb 12, 2008 | 10:08 PM
kahunaking's Avatar
Make sure its not cracked when you reinstall it. Mine was and it turned out to be the reason I have a missing piston. No oil pressure = spun bearing + limping it back = boom.
