Lifter
Old Feb 16, 2008 | 08:29 PM
SprayedZ's Avatar
Default Lifter
Does anybody have a site were i can get the ls7 lifters for my 95 camaro?
Old Feb 16, 2008 | 08:40 PM
Ralls's Avatar
I think these are them http://www.sdparts.com/product/12499...esSetof16.aspx
That's the cheapest I have found them. I'm thinking about getting a set while the motor is apart.
Old Feb 16, 2008 | 09:00 PM
SprayedZ's Avatar
Yeah thanks.
Old Feb 16, 2008 | 09:04 PM
SprayedZ's Avatar
Also, i am doing a hot cam swap. Do i have to get different valve covers, bc of the 1.6 rr? Or will they fit under the stock valve covers?
Old Feb 16, 2008 | 09:22 PM
Ralls's Avatar
You really don't need new valve covers for any 1.6 RR's. Not sure about the hotcam, but usually all you have to do is notch the supports under the valve covers.
Old Feb 17, 2008 | 02:36 PM
SprayedZ's Avatar
What do you mean notch them?
Old Feb 17, 2008 | 03:07 PM
krill's Avatar
The GMPP LT4 1.6 rockers fits without modification under stock valve covers.
Old Feb 17, 2008 | 03:09 PM
3pnt4maro's Avatar
I used the crane golds and had to notch mine just a hair..not much at all but the GMPP i heard will fit
Old Feb 17, 2008 | 06:19 PM
iceman15's Avatar
Now do you have to get different size pushrods if you use the ls7 lifters? I heard the plunger in the ls7 lifters are deeper or something along those lines
Old Feb 17, 2008 | 06:36 PM
SprayedZ's Avatar
Idk do you??? That is a very good questions. Does anybody know?
Old Feb 17, 2008 | 07:01 PM
SprayedZ's Avatar
can someone point me in the way i need to go with motor mounts? Solid or not? Can someone give me a website with what i need? thanks
Old Feb 17, 2008 | 07:05 PM
Ralls's Avatar
You probably won't be happy with solid mounts if it's driven on the street. My friend had them and you'll feel vibration idling and reverse. You will need a solid tranny mount if you get solid motor mounts.
Old Feb 17, 2008 | 09:02 PM
SprayedZ's Avatar
So do you think that these will work good or is there some other brand that i need to get?
http://www.jegs.com/webapp/wcs/store...0002_534813_-1
Old Feb 17, 2008 | 09:17 PM
Ralls's Avatar
Personally, I would get Energy Suspension brand.
Old Feb 17, 2008 | 09:27 PM
SprayedZ's Avatar
Who sells them and were can i get them?
v7guy's Avatar
http://www.frrax.com/rrforum/index.php?showtopic=4599
I've read some comments that guys have broken the trans case with solid motor and tranny mounts. I run solid motor mounts and a poly trans mount. Works fine for the last three years.
The LS7 lifter is suppose to be the same height as a stock piece, as I recall it is now the standard lifter replacement from GM for all hyd lifters.
http://web.camaross.com/forums/showt...ght=LS7+lifter
The Cadillacs lifter with ceramic internals is suppose to require a different length pushrod their supposedly rock solid reliable to 9000 rpms
There is more info on this board and CZ if you do a search.
Old Feb 17, 2008 | 09:42 PM
SprayedZ's Avatar
Well thanks for that info, i am def going with all poly mounts. Does anybody know were i can get the Energy Suspension mounts?
Old Feb 17, 2008 | 11:50 PM
SprayedZ's Avatar
Ok i found the motor mounts at summit but it says left motor mount and they dont sell the right?? what is up with that?
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 18, 2008 | 12:31 AM
Ralls's Avatar
It says use 3-1116 for the right mount in the install guide. So it's ENS-3-1116G or ENS-3-1116R (red or black)
Old Feb 18, 2008 | 01:27 AM
SprayedZ's Avatar
So i just need to buy two of them? It dont matter, it just depends on if want red or black?
