Newbie Question?
Old Feb 17, 2008 | 10:49 PM
LM97Z's Avatar
Default Newbie Question?
I posted over in the Nitrous section & got no answers, but someone told me to come here, anyways, i have a few questions, this will be my first 97 Z28, i've owned a 94, i'm alittle confused on what engine ie actually has, i've seen that maybe 97 was a crossover year for engines, do i have an LS1 or the LT1, i haven't gotten the car yet, its a 6sp., has 157,XXX miles, well kept & maintained, my main Question was about installing a 125 powershot system i have for a carburated engine, what all will i need for the install, i'll just throw in these other questions too not to start other post, any info would be grately appriated
1st. Am i playing with fire running nitrous with this many miles or should i just do perf. up-grades?
what engine do i have?
what can i do to it other then nitrous to have it run low-mid 13s?
thanks in advance.
Old Feb 17, 2008 | 11:01 PM
Spiers's Avatar
It has an LT1. LS1's came in Camaro's 98-02. With just bolt-ons (Intake, exhaust, etc.) you can run mid-low 13's...without N20. But you shouldn't have a problem running nitrous on it with that many miles, if its been well kept as you say.
Old Feb 18, 2008 | 01:08 AM
LM97Z's Avatar
Thanks, this is some of the stuff thats been done to it.
K&N H Flow air filter kit
HP mass air flow sensor
Magnaflow exaust (full length) with H Flow cats, stock manifolds though.
Hypertech power programmer
Ram HP clutch
Poly engine/trans mounts
B&M short throw shifter
Greasable F&R poly anti sway bushings
Tubular Granatelli rear control arms & pan hard bar
Edelbrock tubular torque arm
KYB struts & shocks
Cross drilled rotors F&R
Russell stainless brake lines all around.
& more
I can't wait to get it, i'm sure it'll handle & stop good, from these up-grades, do you see it into the 13s?
Old Feb 18, 2008 | 01:12 AM
Spiers's Avatar
With those mods listed I would say high 13's...
