help/advice on a sc 383 build
Old Feb 20, 2008 | 08:11 PM
transamsam98's Avatar
Default help/advice on a sc 383 build
ok I think ive figure out how I want to do my build up now. I will be doing a low compression 383 probably and eagle set up im thinking 9 to 1 with an le2 heads and cam package and 9psi of boost from some sort of supercharger. crane 1.6 roller rockers ls7 roller lifters pacesetter longtube headers with egr and air deleted. with a spec 4 clutch and an aluminum flywheel. an aluminum driveshaft with a dana s60 rear end with either 3.42's or 4.10s. I have a set of sphone adjustable lower control arms weld in subframe connetors and magnaflo high flo cat and cat back already installed. any pointers or information would be awsome as well as any help geeting these parts cheap. I dont mind used I just dont want beat up. also I have a set of cast iron heads from an ss impala should I send those to be ported or should I invest in a set of aluminum ones? also I am probably going to get the intake ported as well.
Old Feb 20, 2008 | 08:49 PM
CRAZZ28's Avatar
I would think about the S60 again. If you are not dead set on getting it that is, It is too much weight and a little overkill IMO a 9" will be just fine for as much HP as you can throw at it.
Old Feb 20, 2008 | 10:43 PM
at the moment nothing is set in stone exept the over all plan wich is low compression 383 boosted with 9psi or more the le2 heads and cam maybe le3 upgraded rear of some sort the ls7 lifter and l.6 roller rockers other than that i am open for companies recomendations anything to help me build her up.
