Loctite inside engine? and mounts?
Old Feb 26, 2008 | 08:37 PM
Pro_built7's Avatar
Default Loctite inside engine? and mounts?
hey guys im putting prothane engine and trans mounts on right now and i was wondering if i should use loctite on the mounts for both the engine and trans??
Old Feb 26, 2008 | 09:28 PM
fergymoto's Avatar
No need for it IMO. I've never had any come loose before.
Old Feb 26, 2008 | 09:37 PM
Pro_built7's Avatar
ya i was thinking that too, but now that i have a cam and poly mounts i think i might use a dab anyway
what im really wondering tho is if i should use loctite with the internal engine bolts like the spider and camshaft retainers etc stuff like that you know ?
Old Feb 26, 2008 | 10:06 PM
GIZMO's Avatar
No Loctite. Just torque everything to the factory spec. and you will be fine.
Old Feb 26, 2008 | 10:34 PM
fergymoto's Avatar
I use blue loctite on the cam sprocket bolts and cam thrust plate bolts and tighten to factory specs. That's it.
