95 Z28 Engine Misfire
Old Mar 1, 2008 | 06:01 PM
99blue-Z's Avatar
Default 95 Z28 Engine Misfire
I have a 95 Z28 that seems to be having a terrible misfire. It happens horribly when the car warms up. It's smooth till you try to floor it from about 40 mph then it stumbles and shakes until you let off the gas. Sometimes it will keep stumbling after you let up. Also, it has a horrible backfire. My mechanic seems to think there is a performance cam in it, (I am unsure of the history on the car, but it runs rich too). I think it might need tuning, I just wanted to get some opinions from some of you guys before I do.
Old Mar 1, 2008 | 06:18 PM
LT1's Avatar
LT1
check engine light flashing? theres a number of things it could be, clogged air filter, clogged cat, plug wires, plugs, or even optispark, to bad coil. check them before doing a tune.
Old Mar 1, 2008 | 11:25 PM
Jay z28's Avatar
I have a '95 and mine was doing that and it was the plug wires. Although mine did it at idle Also
Old Mar 2, 2008 | 12:18 AM
sweet-94z28's Avatar
sounds like plug wires to me
Old Mar 2, 2008 | 02:09 PM
99blue-Z's Avatar
Well, something I fogot to mention in the initial post was: Optispark has been replaced, plugs and wires replaced as well. I also have no engine light either.
Old Mar 2, 2008 | 02:20 PM
LS1_K1DD's Avatar
Are you plug wires arcing on anything at all? Like exhaust mani/headers(depending on what you have) or maybe a heat sheild? Make sure all plug wires are tight and away from those sorts of things. Start it up and look under the hood at the wires and see if you see any flashing/spark.
Old Mar 2, 2008 | 06:53 PM
96lt1m6's Avatar
really does not matter if the parts were just replaced it's an electrical componet and it can go bad at any time!
i vote for WIRES cause they are cheaper to replace....easier to inspect too.
Old Mar 2, 2008 | 07:46 PM
97badass's Avatar
I'm watching in on this one, my car does the EXACT same thing! hope you get it figured out.
Old Mar 2, 2008 | 09:39 PM
99blue-Z's Avatar
I thought plug wires as well (searched the forums) but they look good, and I don't have any arcing or sparking...
Old Mar 2, 2008 | 11:24 PM
LS1_K1DD's Avatar
Horrible backfire may be from a timing issue. But do remember Most LT1's are prone to backfiring, its just a thing they do. Mine never did it, i would say maybe 50% do. Im sure others will chime in on that.
Old Mar 3, 2008 | 09:54 AM
97badass's Avatar
another idaho person! lol back on subject
anyways back on topic, did you try cleaning the maf?
Old Mar 3, 2008 | 02:35 PM
LS1_K1DD's Avatar
Yeah there is a couple of us around here. I know a couple 2-3 more guys locally on here. Where you at in ID?
Old Mar 3, 2008 | 03:14 PM
SlowGreenTA's Avatar
Mine acted like this with a bad O2 sensor, but it also threw an O2 sensor code, so it may be worth checking! The thing that sounds exactly like mine is it ran ok until you tried to give it some gas, then it would sputter and try to die.
Old Mar 3, 2008 | 05:30 PM
97badass's Avatar
west of rexburg a little ways
Old Mar 3, 2008 | 07:54 PM
LS1_K1DD's Avatar
Nice not to far away from me then, im down in the Burley/Rupert area. , an update on the thread at all?
