LT1- Will a 94 work in a 96????????
Things to consider though: If you're putting the 94 into the 96 car and keeping the 96 Computer, you're going to have to change timing covers, which is going to necessitate changing the camshaft and opti as the 94 stuff isn't compatible with the 96 stuff. Why? Because the 96 NEEDS the CPS to run. Thus, it needs the timing cover for the CPS to mount in to. But, the 96 timing covers opening for the opti is larger than that of the 94's timing cover.
Just be ready to open the motor up to change some stuff around and you'll be fine.
I honestly didn't know that.
