ATI damper question
Old Mar 3, 2008 | 09:25 PM
chas010's Avatar
Default ATI damper question
Does anybody have any experience with damper part no 917271? I bought one used off ebay and installed it on my 1995 camaro and then while reading the ati website noticed something about a 916320 hub spacer, do i have to pull this all back apart?
thanks jason
Old Mar 3, 2008 | 11:20 PM
Karl Ellwein's Avatar
If you have a 93,94,95 Fbody with the stock accessories then you should have the spacer installed between your crank sprocket and the ATI hub so that it can create the exact same spacing as the stock hub/damper for accessory alignment, (serp belt).
If you have a 96/97 Fbody then you don't use that spacer.
The spacer takes the place of the crank reluctor for cars that do not have a crank reluctor.
Karl Ellwein
Old Mar 4, 2008 | 11:39 AM
chas010's Avatar
Thanks Karl,
I called ATI and there getting that spacer out to me. I was just dreading pulling that damper off again, Im afraid for my crank threads 74ft/lbs seems like alot of torque on that bolt
Jason
