budget build
Old Mar 4, 2008 | 01:37 AM
slick1851's Avatar
I would also check out the water pump to make sure its not leaking etc since your going to be down there, and check the rear main seal( Normal leak)
Also you really should get a new OIL pump with the cam swap, along with all the other basic stuff and upgraded timing chain
Old Mar 4, 2008 | 11:40 AM
KriegerEhre's Avatar
Just replaced waterpump, seals are fine replaced them few months back. . . .planned on getting a new oil pump - and defenitly will change the timing chain !
