cleaning up un der my hood ......
Old Mar 4, 2008 | 06:51 PM
saylorZ28's Avatar
Cool cleaning up un der my hood ......
hey i have searched and no luck but is there a stickie or anything on cleaning out everything you dont need under your hood ... like smog egr ... lines hoses ect.ect..........
Old Mar 4, 2008 | 06:54 PM
camaro-94-z28's Avatar
carbed 572. no anti lock brakes. a/c just throttle fuel and ignition and radiator headlights. that cleans everything up. lol i dont know for your real question
Slvr00Bird's Avatar
I'm sure there is.. I thought you meant appearance as in the wire mod.. There are some write ups on it as well.. Just do a quick search and you'll have all you need.
Old Mar 4, 2008 | 07:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Just get in there and start ripping stuff out. For the EGR/Air if you don't have race headers you'll need block off plates. You'll need one for the back of the intake manifold period. I used the stock one, whacked the tube out of it, cut the tube up, flattened it, and welded it over the hole. !ABS you'll need a proportioning valve. You can reroute the fuel lines through the back of the fender. All you'll need is a 2 inch grommet and some zip ties. That's all I can think of off the top of my head. LALT1 has a lot of good info in his fuel line thread.
Old Mar 4, 2008 | 07:23 PM
transamws6_97's Avatar
yeah you can take out the emissions...air and egr...
if its not a daily driver you can rip out the a/c
there is the wire hide mod where you take the wires running down the passenger side and hide them under the shock tower. there is the mod to relocate the fuel line.
also you can relocate the battery to your rear trunk.
