steering linkage problem
Old Mar 4, 2008 | 09:45 PM
95phoenix's Avatar
Default steering linkage problem
hey guys, i need some help getting my steering linkage back on after my pacestter LT install. i've tried everything and i just cant get it back on.
i have always been able to find the help that i needed by searching, which is why i have yet to post. but i cant seem to find anything about re-installing it. so if anyone has any tips on a way to get it back on i'd apprieciate it.
btw its a 95 t/a
thanks
Old Mar 4, 2008 | 09:50 PM
transamsam98's Avatar
I used a peice of pipe with a rubber stopper on the end of it lined up the steering linkage and tapped it back into place using the pipe and a mallet. also a lil bit of wd 40 helped it go on easier.
Old Mar 4, 2008 | 09:54 PM
95phoenix's Avatar
are you talking about for the bottom or top?
i should have mentioned i have the bottom on i just cant get the top part on.
Old Mar 4, 2008 | 10:05 PM
both but to get the top back on it took alot more finess and a shorter pipe as well as a litle bit of and angle
Old Mar 4, 2008 | 10:11 PM
95phoenix's Avatar
ok i'll keep hammering away at it then. thanks for the help.
