How hard is it really ?
Old Mar 7, 2008 | 01:24 PM
djjab57's Avatar
Default How hard is it really ?
Alright guy's, ive done a lot of work on my 94 LT1 Z but have never changed the oil pan gasket. But of course its now time. I was at the track teching In as was turned away because i was dripping from the front of my pan. What all needs to be dropped and moved out the way? What are the little techniques you have used to make it easier on the A4
Old Mar 7, 2008 | 04:20 PM
bricez28's Avatar
well i just did mine and the motor had to be jacked up and all sorts of mayhem. wasnt fun
Old Mar 7, 2008 | 04:22 PM
Revelation Z28's Avatar
do the motor mounts while you're there and plus you are gonna be unhooking them.
jack the engine up from the bellhousing and keep it up there about 2" above where it usually sits mounted.
Old Mar 7, 2008 | 04:25 PM
djjab57's Avatar
Whats the best ounts to use
Old Mar 7, 2008 | 04:28 PM
prothane mounts usually. check out thunderracing or TSP, since you are close to them youll get em in a day or two.
Old Mar 7, 2008 | 05:05 PM
fordeater's Avatar
i just did mine this winter while I was doing the h/c swap, and put a new oil pump in also. I am an m6. It was not a fun job. I jacked the motor off the mounts as much as I could, then loosened all 6 K-member blots just enough so they did not completely unthread. take off the starter, and flywheel cover and all the oil pan bolts, also you will have to remove the oil cooler if your car is equipped with one. Its definetly not a easy job and if you are not a mechanically inclined person you should not try doing it. and another good tip is to take out the oil level sensor first, i didnt my first time and broke it.
Kevin
Old Mar 7, 2008 | 05:48 PM
djjab57's Avatar
Like most F-Body owners ive been pretty deep into mine i was just wondering about the things to exspect and to look out for such as oil level sensor thanks for the info anybody else wants to chime in please do I knew it was going to be a pain in the a** when my buddy told me the shop charged him $200
Old Mar 7, 2008 | 05:59 PM
fordeater's Avatar
if a shop is only going to charge 200$ to do it then do that! haha
Old Mar 7, 2008 | 06:17 PM
djjab57's Avatar
A whole weekend or $200 it does make sence to let it be someone elses headache
Old Mar 7, 2008 | 06:21 PM
fordeater's Avatar
its just a pain laying under the car, trying to get a good bead of rtv on it, and set it in place without messing the rtv up, I had to do it twice because the first gasket slid and screwed up the silicone. its a job that I would not like to do again, if someone was only going to charge me 200 to do it I would jump all over it, that would of prevented me from waking up at night in a cold sweating dreading doing it.
Old Mar 10, 2008 | 12:20 PM
djjab57's Avatar
Well i think ive been talked out of doing it myself
Old Mar 10, 2008 | 01:27 PM
355z28's Avatar
I did it myself, it wasnt really all that bad i thought. But then again We have a floor hoist..
Old Mar 10, 2008 | 01:40 PM
bobdec's Avatar
djjab57, If you're only leaking from the front (where the oil pan and timing cover mate) you may get away by only changing the front rubber gasket not the complete oil pan set. To change it you have to remove all the front pan bolts leaving the the rear bolts intact. Then carefully pop the front of the oil pan down about 1/2 inch or so, wedge a screwdriver handle or something soft to hold it open. Throughly clean and dry the mating surfaces, trying not to drop anything into the pan, then apply RTV and new rubber seal.
Old Mar 12, 2008 | 10:24 AM
djjab57's Avatar
Its just the front Dont see any oil on the sides
Old Mar 12, 2008 | 10:57 AM
B-Rad420's Avatar
With the prothane mounts and pacesetters long tubes you will get a lil bit of rubbing from the steering shaft upper bolt. At least I do but I have 3+ year old pacesetters and they mave have changed the design. Brad
Old Mar 12, 2008 | 11:21 AM
Formula350's Avatar
Are we not liking the one piece rubber oil pan gaskets from Fel-Pro (and I'm sure others) that don't require RTV?
BTW, the Garmin might actually lie I think when you're going that fast, it's going to have a hard time distinguishing your actual speed. When I had a GPS for a few days, I liked that feature but found that to actually get it to read my actual speed, I had to be driving the same speed for about a minute. (Sorry to go off topic heh)
Old Mar 12, 2008 | 11:38 AM
djjab57's Avatar
Off topic the needle was buried not quite a min. mayby 30 seconds Im not sure wich way im going to go yet on the gasket im hoping this weekend will be nice so i can get it done if its not i may just drop it off at the shop. My garage floor is looking like crap need to put down the u coat it PS yes i now have a piece of cardboard under it. It only Leaks in the garage while warming it up
Old Mar 12, 2008 | 07:14 PM
bricez28's Avatar
nope mione are a month old and they hit. im gunna dent the headers
