cooling line on back of heads
Old Mar 9, 2008 | 12:26 PM
97lt1z28's Avatar
Default cooling line on back of heads
There is a coolant line on the back of the heads and when i took off my intake manifold to pull the heads to send them to lloyd elliot i noticed that the two washers (not sure if thats what there actually called) that seal between the head and bolt are in pretty bad shape. Where the heck do i buy these things! Its like a washer that has a silicone middle to not let coolant get by, help me find these please
Old Mar 9, 2008 | 12:30 PM
tbird31's Avatar
they're gaskets. you can get them from GM. not sure on the part number but that's the coolent crossover. just ask for the gaskets. shouldn't be too expensive.
Old Mar 9, 2008 | 12:40 PM
Formula350's Avatar
I haven't touched mine, but are they gaskets or are they like brake line washers, brass crush washers?
Old Mar 9, 2008 | 01:03 PM
speed_demon24's Avatar
I just bought mine at summit, they were earls with a 1/2" opening IIRC. Didn't feel like getting raped by GM again.
Old Mar 9, 2008 | 02:14 PM
Jose93z28's Avatar
I just did some head work, and had them replaced with oil drain gaskets Dorman part # 65269 they are metal around the ring and rubber in the center, youll need four of them and they're only about three dollars each, you can find them at your local parts store I got them at advance cause I work there
Old Mar 9, 2008 | 05:36 PM
97lt1z28's Avatar
Alright guys thanks a lot for the help
Old Mar 9, 2008 | 09:51 PM
sbcgenII's Avatar
Here is what I use now.
Heads got striped so I got them tapped to 3/8 pipe have 3/8-6an male in the back off the heads with a swivel tee on the passanger side.
Old Mar 10, 2008 | 12:19 PM
1970judge's Avatar
GM, i have some in stock.
Old Mar 10, 2008 | 12:31 PM
96slow6's Avatar
Go to napa, ask for part number 730-2922 it goes for 9.26. It has what you need.
Old Mar 10, 2008 | 12:32 PM
96slow6's Avatar
Oh its the A/C seal kit. Take a look at the seals. You will be happy you read this.
