Is the MAF related to fan operation?
LT1 coolant temp sensor- PCM (pump) (AC-D #213-310) (93-97) , GM part number: 15326386 (formerly - 12146312)
Also, you said you put in a new thermostat, is it stock or is it a lower temperature stat? You'll need to have your computer tuned to change the stock fan turn on temp or you wont get the full benifit of the new stat unless the car is moving. You could also hook up a manual fan switch instead.
I used a stock thermostat, even though the one I pulled out seemed good. bobdec... I know the fans work, so the relays and operation of the fans are ok. So I guess the computer just isn't reading the temperature correctly, so this would be a bad sensor in the water pump or block??
I'm not doubting infinitebird, he seems right, but is it correct that the fans come on when I unplug the MAF only because the computer is programmed to turn them on when a certain code shows up?
Yes that's correct. The sensor on the water pump is used by the computer. The one on the driver's side head is used for the dash display.
