ram air vs. cold air
Old Mar 9, 2008 | 07:18 PM
TheBlackZ28's Avatar
Default ram air vs. cold air
i have a 93 z28 with a harwood 2.5 cowl hood and in debating on either going ram air or cold air. right now all i have is filter straight to throttle body. any comments on which is better to run with my nitrous system?
Old Mar 9, 2008 | 07:53 PM
CALL911's Avatar
If you are asking which is better between the factory Camaro SS ram air system and the standard cold air system, then the cold air system is better as the air isn't "pre-heated" over the intake first (even if you are using the spray).
Now, if you are asking which is better between the traditional firebird ram air, or the ram air that works with the Ultra-Z hoods that goes straight into the MAF and straight into the TB vs the standard cold air system, then the ram air system or Ultra-Z hood ram air system is the better more power potential making system with, or without nitrous.
Old Mar 9, 2008 | 08:00 PM
I thought the ram air might but i dont have a maf so my ram air will go direct so that might just be the way i go.
Old Mar 9, 2008 | 09:08 PM
StealthFormula's Avatar
I would go CAI because theres no vents in your hood to fully utilize a ram air setup I would imagine a CAI would work much better in your case because it will be taking in the cold air from under the car instead of the warm air near your engine.
Old Mar 10, 2008 | 06:20 AM
CALL911's Avatar
This is ture.
Old Mar 10, 2008 | 06:45 AM
nighthawk15's Avatar
Ram air works well on carbed engines for obvious reasons, but for modern injected cars that do not have an air cleaner sitting right on top of the engine like the old carbed ones, a CAI is just a much better design. Ram Air is in the top of the engine bay (the hottest part), plus the LT1 ram air systems have very sharp bends in them. A cold air system sits down toward the bottom and has very smooth bends. You do the math.
Old Mar 10, 2008 | 06:16 PM
Thank yall for the input, i do appreciate it. I was think ram cuz 93s dont have mafs so with a ram air hood i might be able to just make a fitment to go straight in but that was cut out due to it being a dd now so i think i am going cai.
