Transmission
Old Mar 11, 2008 | 08:46 PM
everclear4520's Avatar
Default Transmission
would a 95 5.7 Buick Roadmaster Tranny direct fit in a LT1 Camaro
Thanks Matt
Old Mar 12, 2008 | 06:07 PM
does no one know about this?
and help would be great
Matt
Old Mar 12, 2008 | 06:09 PM
Prototype007's Avatar
Matt
Do you know what the tranny model is in the Buick?
I'm fairly new to the F-Body thing so I'll try and help you the best I can.
Old Mar 12, 2008 | 07:19 PM
socal's Avatar
Yes it will fit, it should be a 4l60e but the real queston is what year camaro. In 96 they swiched the pumps to PWM (pulse with modulated)so thats what need to match the ecm.
So if it's a 94-95 you should be ok, 93 is a 700r4, and the 96,97 would be the 4l60e as well with the pwm, you can look at the pump and see it pwm is cast into it. The tail shaft off the f- body will have to be reused as well.
Old Mar 12, 2008 | 09:41 PM
so the tail housing on the buick roadmaster tranny is different? then on the regular F-body trannys
Old Mar 12, 2008 | 09:55 PM
GMRACER13's Avatar
Yes, the F-body tail housing has the three holes for the torque arm bracket, the buick tail doesn't. the tail housing is held on by 4 bots and it's easy to change. If you have some sort of aftermarket torque arm relocation bracket which moves the torque arm off of the tail housing then it makes no difference which tail you have.
Old Mar 16, 2008 | 02:49 PM
does anyone know where i could buy a F-body tail housing
Thanks Matt
Old Mar 16, 2008 | 03:09 PM
96capricemgr's Avatar
Actually the trannies were slightly different each year 94/95/96 the 95 is PWM just not the same PWM as 96. So you need to tell us what year your car is too.
Old Mar 16, 2008 | 06:36 PM
i'm gonna be using a 95 roadmaster tranny and the pcm that came with the 95 roadmast but use a 97 A4 Harness its all going in a 95 Z28
Thanks Matt
Old Mar 18, 2008 | 06:09 PM
anymore help guys?
Old Mar 26, 2008 | 06:46 PM
any help?
Old Mar 26, 2008 | 06:52 PM
throttlejunkie1's Avatar
Try posting this in the Transmission section...Good luck!
