Curious about the stall wall issue.
Old Mar 12, 2008 | 01:29 PM
ScreaminRedZ's Avatar
registered user
Default Curious about the stall wall issue.
What size stall does this become a problem and what's the fix? Not going to be an issue for me for a little while, but I'm just curious.
Old Mar 12, 2008 | 04:06 PM
The LT1 That Could's Avatar
3000 +, only on the OBD1 cars, and several PCM tuners out there have the fix for it.
Old Mar 12, 2008 | 08:12 PM
Smokinlt1's Avatar
a tune from Ian solved it for me. I think he changed something with RPM in the constants tables.
Old Mar 12, 2008 | 08:48 PM
buffman's Avatar
there are quite a few adjusments that can eliminate the issue. Rare cases nothing can be done, and the issue with be always present.
Old Mar 12, 2008 | 09:04 PM
infinitebird's Avatar
I believe it is the VSS diagnostic (in the constants).
Although sometimes you also have to adjust shift points so the downshifts always occur very low.
Old Mar 12, 2008 | 09:46 PM
black95formula's Avatar
can mad z28 fix this problem? i just got a yank 3200 and was going to get my tune from him.
Old Mar 12, 2008 | 10:10 PM
CamaroRacing12's Avatar
yea im pretty sure madz28can fix it for ya.. just tell him ur stall and ur mods etc
Old Mar 12, 2008 | 10:12 PM
IronOutlaw's Avatar
if i get a 2800 stall will i have to worry about this?
 Michael S. Palmer
Old Mar 12, 2008 | 10:18 PM
94greencamaro's Avatar
I would guess that you would be ok....
I had this problem with my old Vig 3400. PCM4LESS fixed it no problem. I looked through my LT1edit file after i got it back at what was done to fix it and its a pretty simple adjustment.
Old Mar 12, 2008 | 10:35 PM
yea dude def dont get a diff stall just because of it! i kno a kid who has a 3000 vig and dosent have an issue with it... but even if u do just send ur pcm out and get it tuned out
Old Mar 12, 2008 | 10:40 PM
Slowmaro95Z28's Avatar
I've never heard of this problem. I have a TCI 3500 waiting to go in when the weather is a little better but i'd like to know more about this before I get it in.
Old Mar 12, 2008 | 10:52 PM
Basically if you launch the car hard at the track it hooks and throws an error code. You will continue down the track and hit the rev limiter and then shift from 1st to 3rd. Only way to fix it is through the tune....
As said in above posts its only in OBD1 cars and is most common with stalls over 3000 but doesnt happen to all of them. Kind of hit or miss.
Old Mar 12, 2008 | 10:54 PM
Thanks. That's not too bad since I'm driving distance from PCM for less. I guess I'll find out when I'm launching on a back road near my house. lol
Old Mar 12, 2008 | 11:17 PM
thats sweet just have him give ur car a in person tune, does he dyno tune?
Old Mar 13, 2008 | 04:58 AM
registered user
Thanks guys! That'll come in handy when it's time to choose a stall/programming.
