a4 and m6 crank diffrence
Old Mar 13, 2008 | 06:46 PM
Ari G's Avatar
Default a4 and m6 crank diffrence
Is there any diffrence in the crankshafts exclunding the balancing?I´ve heard something about it but never seen it
Old Mar 13, 2008 | 06:57 PM
96capricemgr's Avatar
The M6 crank should be the same BUT has a pilot bushing installed for the input shaft to slide into. Not really a crank difference but something you need to address if swapping auto to manual.
Old Mar 13, 2008 | 06:59 PM
camar0corey's Avatar
ah ****, can this been done with the engine assembled? Upon reflection this sounds like a retarded question considering all the A4 to M6 swaps out there.
Old Mar 13, 2008 | 07:22 PM
sure it can be done engine assembled just have to have the tranny disconnected from it.
There are bearings available too but I believe most guys opt for bushings.
Old Mar 13, 2008 | 08:11 PM
Ari G's Avatar
Ok,thought so
I removed my m6 crank and replaced it wit an a4 but there wasent a bushin in the m6,i´ve driven it and seems fine,what could i damage other then the trans?
Old Mar 13, 2008 | 08:24 PM
B-Rad420's Avatar
I have auto b-body short block (auto) in my car and a 6 speed and everything related to that seems fine.
Old Mar 13, 2008 | 08:41 PM
I never ran a manual without a pilot bushing, I would guess though that it is hell on the input shaft bearings.
One of those I would never try it to find out sort of things.
http://www.autozone.com/R,APP265083/...ductDetail.htm
