LT1 timing chain and gear question
Old Mar 13, 2008 | 08:52 PM
crazycat's Avatar
Default LT1 timing chain and gear question
I am having my 383 turbo engine being built now and I need a new timing chain and gear, But the lt1 set up is $200 to $250 for the extreme duty.
I was told that I could use one for a 86 and up if I am using electric water pump.. Is this true ? Like this one. Thanks http://store.summitracing.com/partde...5&autoview=sku
Old Mar 14, 2008 | 01:53 PM
crazycat's Avatar
Well I just called jegs,and they said I would be able to use a standard chain and gear as long as I am using an electric water pump..
Old Mar 14, 2008 | 03:40 PM
Purple95Z28's Avatar
Just keep in mind if you want to use a double roller the inside of the timing cover will have to be clearanced a little.
Old Mar 14, 2008 | 04:21 PM
crazycat's Avatar
O.K thanks..
