LTCC guys post your pictures!
Mounting in this location allowed me to use a stock set of wires (MSDs) because the coils are equal distance to the frame rails as the distance to the opti.
https://ls1tech.com/forums/showpost....86&postcount=8
Then the rotor fell off, and then the optical half got all pissy and the car would die. I got really tired of fixing my **** at the track instead of driving it. Also burned some wires on my headers and really disliked how hard they were to remove. I also like the idea of a spark based rev limiter, because I hit it from time and time (and fuel cut makes me sad in the pants).
Stock LS1 coils off of a C5. Thanks for the compliments; it came out better than I thought it would.
If your opti works for you, then great. If it doesn't, this is a great option IMO. I've had way too much trouble with me to ever consider going back, and my LTCC setup has worked great.
Anyhow - back on topic- the reason I never installed the LTCC was the mass of wiring- I was intimidated to try it myself. But looking back- I kinda wish I did.
I inspired myself from the MBA fuel rail cover with mounting brackets for coils.
I ve machined 8 individual coils(im using ls2 one) brackets from 6061 billet aluminium(yeah im picky
) .And for the plate i ve took some aluminium sheet(dont remember the thickness) and bent it to the good angle.The wire all pass under the plate and only the connector pass thru a hole on top on the coils.
Nice and clean
