Cam Change question
Old Mar 15, 2008 | 09:54 AM
Burning Rubber's Avatar
Default Cam Change question
I have a 96 LT1 and I recently changed to a CC306 Cam. I had an oil pressure issue under WOT. So I took it apart and the oil pump drive gear is all chewed up. I was wondering if there is a special gear for the pump drive that you need to use when changing the cam out.
