Raptor shift light install
Old Mar 15, 2008 | 05:45 PM
wwmost's Avatar
Default Raptor shift light install
i just got my raptor shift light but i need a tach signal to hook it up too. it says on the site 96-97 directions but not 95, is it different? where can i tap my shift light into? and also how many cylinders do i put the shift light on? i tapped it on my mustang using a coil pack while and it said to put it on 1 cylinder mode if i was doing that, worked fine. thanks!
Old Mar 16, 2008 | 05:59 PM
wwmost's Avatar
ttt.....
Old Mar 17, 2008 | 12:40 PM
wwmost's Avatar
i guess no one installed a shift light
Old Mar 17, 2008 | 12:46 PM
My93Z's Avatar
There is a blue connector under the passenger side kick panel. Here is a link: http://shbox.com/1/harness_connector_faces.htm
It is connector C230 in cavity d
Hope this helps
Old Mar 17, 2008 | 12:50 PM
wwmost's Avatar
what is the website telling me? so i look for a blue connecter under there? what wire is it?
Old Mar 18, 2008 | 06:07 AM
My93Z's Avatar
If you look at the bottom of the website there is a tab for C230. Then scroll down to 1995. Look at the chart under cavity for "D". The description is "Tachometer signal to instrument cluster". Now goto you car, remove the passenger side kick panel. There are some wire connectors. One of them is blue. On that connector find the the lablel "D" on the connector. There should be a white wire coming out of the that cavity. Splice your tack wire into that wire.
Old Mar 18, 2008 | 07:17 AM
wwmost's Avatar
OOOOO thank you!. now i got it. i didnt see the tabs on the bottom
