No Start Condition on my 94 formula
Old Mar 16, 2008 | 03:02 PM
blackbird94's Avatar
Default No Start Condition on my 94 formula
well my 94 formula is having a little trouble starting. The ignition turns on but when i turn the key i get nothing. I thought it may have been the starter silenoid so i replaced the starter and still nothing. My buddy came over and helped me check out some of the relays. Also we jumped the terminals on the starter and that is fine. So i got power and and the sarter is in good. We tested the theft deterrent relay and the shifter position relay and the seem to be ok. We bypassed the TDR and it would start then die in a matter of seconds. We were trying to pinpoint the problem. We tested the little block on the ke and it doesnt seem to be conducting through both sides. Could this be my key? Or is it a good possibility of a faulty wire somewhere????
Old Mar 16, 2008 | 06:11 PM
bump!
Old Mar 16, 2008 | 06:25 PM
95hitam6's Avatar
i got the same problem, i'm this close to just changing the starter and see if that helps. if you find the prob. please post it up.
Old Mar 16, 2008 | 10:12 PM
Brewski's Avatar
93 T/A is going through a similar behavior there's a delay after turnng the key where nothing happens then the motor starts to turn over and the car fires up.
Take it easy
Brewski
P.S. In my case I'm going to be trying the VATS/Key troubleshooting described in other posts in the forums cleaning key/contacts etc....
Old Mar 17, 2008 | 02:12 AM
gatorhead's Avatar
Thats a good place to start! Pun intended lol
Old Mar 17, 2008 | 09:19 AM
well occasionally before. i would turn the key and get nothing and then tried again and it would fire right up. Ive eliminated the fact of it being the starter. I guess my next best bet would be a new key.
Old Mar 17, 2008 | 09:31 AM
95zpro's Avatar
I would try your ignition switch; although on mine I had trouble turning the key.
Old Mar 17, 2008 | 10:12 AM
djjab57's Avatar
Same here mine went out a few times would crank then die, i could drive for a while then would take forever to start back up. You can pick one up for about 20 at any autoparts. I would just drop the column and pull out the connecters most of the time if there going out they will have burn mark's on the plastic
Old Mar 17, 2008 | 10:45 AM
UnitZ28's Avatar
you can take the pellet out of the key and solder it in between the two wires that check the pellet easy fix
Old Mar 17, 2008 | 12:26 PM
lt170chevelle's Avatar
hey i had similar problems when i swapped out my motor. might not be it but make sure your shifter cable is adjusted right on the side of the trans. mine wouldnt start cuz something was out of wack between the shifter and trans cable linkage so i adjusted and did fine..try putting it in neutral and see if it will start
Old Mar 17, 2008 | 03:45 PM
i tried neutral and nothing still.
Old Mar 17, 2008 | 04:04 PM
djjab57's Avatar
I would bet ignition switch
Old Mar 18, 2008 | 10:24 AM
is that in the column???
Old Mar 18, 2008 | 10:26 AM
gatorhead's Avatar
It is the receptacle where you put your key in!
Old Mar 18, 2008 | 10:32 AM
djjab57's Avatar
No it sits on top of the column right on top in the middle you have to drop it down has to plugs going into it
Old Mar 18, 2008 | 10:45 AM
djjab57's Avatar
To check it heres what you have to do take the cover off the botton of the column (take out your fuse for air bag to be safe) take the 3 bolts off the floor pan were the column goes in the fire wall then take out the to bolts
that hold the v shape piece under the column and then the 2 bolts that hold the column up. when it comes down you will see it right there on top has 2 tiny screws holdind it in place. you can unplug it and check for any burn marks but you might as well replace it they do go bad When you put it back in just make sure you Have The Brake safty switch back in the right place before you tighen it all back up and put it together another words just make sure it starts you may have to ajust it a little the only problem i had was getting the tiny back screw back in but its really easy
ThoR294's Avatar
if your car starts and runs sometimes... i would assume your starter is good... clean off your key real good
Old Mar 18, 2008 | 11:16 AM
djjab57's Avatar
and also use a can of compressed air to clean the contacts inside the key hole and q-tip with alcohol
Old Mar 18, 2008 | 04:26 PM
i will try the key, and then if thats not it i will check the ignition switch.
Old Mar 27, 2008 | 06:03 PM
well the key i had wasnt putting out a code. So i got a new one and i still have nothing. I guess i gotta check out the ignition switch.
