cc503
Old Mar 19, 2008 | 01:03 PM
stevema10631's Avatar
Default cc503
i am looking at the cc503 cam but am wondering if the 112lsa is able to pass the sniffer, i have heard people say that the 112 is tough but the 114 should no problem but i cant seem to find a 114 lsa anywhere in the cc503
Old Mar 19, 2008 | 02:20 PM
BizZzatch350's Avatar
Moderator
You'd have to ask some one to grind it for you on a 114 when you order it.
Old Mar 19, 2008 | 02:37 PM
StealthFormula's Avatar
or you can get the 112lsa and have it tuned so it will pass. As long as the idle is bumped up you shouldn't have any problems and a tuner will take care of that for you no problem.
Old Mar 19, 2008 | 04:46 PM
so a 112 will work with a good tune, because i read alot of people saying its still rather difficult and thats the last thing i want to have to do is screw up the emmisions and not be able to drive it on the street.
Old Mar 19, 2008 | 05:07 PM
email bryan at pcmforless. I emailed him about that on my old '95 LT1 and he assured me it could be done without a doubt. Im assuming you want the 112 for idle purposes? because the 114 will sound fairly stock.
Old Mar 19, 2008 | 07:33 PM
PCMFORLESS's Avatar
I've had the 503 pass even in CA. It's grind seems to run very clean, typically even cleaner than the hotcam. It has a very good burn even at idle and part throttle.
I really like the 503 for it's broad torque curve and good HP numbers.
Old Mar 22, 2008 | 11:20 AM
any other cams you guys might suggest i appriciate it that you guys can get it to pass emmisions, do u think a CC306 would? i know that it may be pusshing it
Old Mar 22, 2008 | 07:50 PM
the cc306 wont pass.
Old Mar 23, 2008 | 02:37 PM
yea i figured ok so im set on the cc503 then tahnks guys
