4 bolt main question
Old Mar 19, 2008 | 01:03 PM
phirepower's Avatar
Default 4 bolt main question
how to tell from vin if an fbody is an original 4 bolt main car
Old Mar 19, 2008 | 01:36 PM
97badass's Avatar
you cant tell from the vin number... you MIGHT be able to tell from the rpo codes or you MIGHT be able to tell by the casting number on the block... but the only way to know for sure is to drop the pan and look inside.
Old Mar 19, 2008 | 02:10 PM
the_merv's Avatar
You can't tell from RPO Codes in the box..it only says Engine type.
Pretty much you have to drop the Pan bro..
Old Mar 19, 2008 | 02:44 PM
bigbadblack93z's Avatar
either block would have the same casting number.
a sure bet would be a "Y" in the vin code.
Old Mar 19, 2008 | 05:01 PM
phirepower's Avatar
there is no y code in the vin, however this summer I pulled the pan and it is a 4 bolt main engine. I'm starting to wonder if this is not the original engine, it felt very strong even when it was stock
Old Mar 19, 2008 | 06:37 PM
engineermike's Avatar
A very few F-body's got the 4-bolt blocks and it's only because they ran out of 2-bolt blocks at the time. I have a friend who found his original block in a Formula was a 4-bolt.
Mike
Old Mar 19, 2008 | 07:22 PM
the_merv's Avatar
Mike
Not necessarily.. if it was a Factory replacement more than likely it was a 4-Bolt.
Old Mar 20, 2008 | 12:11 AM
phirepower's Avatar
so is it a fact that a for the original engine to have been a 4 bolt main, a y would be present in vin. Is this worldly accepted as a fact
Old Mar 20, 2008 | 05:49 AM
leadfoot4's Avatar
Mike
I agree...As far as I know, only the 'Vettes got 4 bolt blocks. It's been a few years since I had the pan off my '96 Z-28, but I'm pretty sure that I saw only 2 bolts mains when I was in there....
Old Mar 20, 2008 | 05:59 AM
No. GM never "officially" offered the 4-bolt in the f-body, so the vin would not have been changed. Unless, of course, the vin also indicates it's a corvette.
Mike
Old Mar 20, 2008 | 01:53 PM
phirepower's Avatar
I'm pretty sure my car isn't a vette lol. Hmmm any other thoughts on this issue? I bought this car from the second owner, car appeared totally stock when I first purchased it, does have four bolt mains. Anybody have a ny ties to a mid 90's gm engineer?
Old Mar 20, 2008 | 02:33 PM
the_merv's Avatar
For a Corvette, yes. A Y will never be in the Body designation spot in a F-body Vin Code cause it's an F-body,
Old Mar 20, 2008 | 05:10 PM
... I bought this car from the second owner, car appeared totally stock when I first purchased it, does have four bolt mains. ..
Just accept that you're one of the lucky few f-body owners that got a factory 4-bolt main.
Old Mar 20, 2008 | 11:12 PM
cshabby's Avatar
yeah put it to good use, lucky bastard
Old Mar 20, 2008 | 11:48 PM
phirepower's Avatar
Will do
