Worse place to drop a bolt?
Old Mar 20, 2008 | 09:57 PM
BizZzatch350's Avatar
Moderator
Default Worse place to drop a bolt?
I think minus the motor I found it. Was installing a new nitrous bracket and dropped the TB bolt, well it decided to fall. I looked for a magnetic pick up tool, none to be found, so I tried nabbin it with the fingers, negatory, **** fell further and now calls some where between the water pump and opti its new home. I think if I took the water pump off I could get at it, but at this point, may just go ahead and buy a new bolt. I'll get that one back when I do a cam swap.
Old Mar 20, 2008 | 10:08 PM
ROWDYZ28's Avatar
umm I wouldn't want a bolt that size just hangin out in there. Take your **** apart and get that thing out. .
Old Mar 20, 2008 | 10:13 PM
ckyconan2003's Avatar
a magnet isnt that expensive either, prolly would cost less than the bolt lol. try and find you a magnet stick.
Old Mar 20, 2008 | 10:34 PM
wwmost's Avatar
^^ lol seriously.
but yea i hate when that **** happens
Old Mar 20, 2008 | 10:37 PM
Moderator
I have to pickup a new magnet since mine is gone, some one do an Amber alert for my missing pen magnet. Sears has one now with an LED light..
Old Mar 20, 2008 | 10:46 PM
Pro_built7's Avatar
Ya.. tends to happen.. you know with 'gravity' n' all.
lol thats funny man i'd get it out of there thats a pretty big bolt to just be chillen there.
for the record my cousin's car was up on jackstands and he was standing on a plywood box and he slipped off the side dropping the oil pump drive bolt down the oil pump drive hole in the back of the engine
Old Mar 20, 2008 | 11:27 PM
Moderator
That sucks ***
Old Mar 21, 2008 | 01:34 PM
the_merv's Avatar
Veteran: Air Force
I was gonna say the same thing..I know someone that dropped an Intake Bolt down the Distributor hole in a 350..
Old Mar 21, 2008 | 04:40 PM
Pro_built7's Avatar
It's an absolute nightmare, you literally have to bend over and grab your ankles, b/c there is nothing.. nothing nothing. you can do about it. its gone.
Old Mar 21, 2008 | 04:52 PM
SLawson86's Avatar
buddy of mine was rebuilding a transmission and for some reason tinkering under the hood. two checkballs fell into the intake into the cylinder and he didnt realize until he started it up... just imagine that noise, two steel ***** having a good old time in that cylinder
Old Mar 22, 2008 | 12:07 AM
GASH1313's Avatar
I lost a throtle body plate bolt while installing nitrous micro switch. Long story short, I found it after it shaterd a pistion on my motor that only had 27,000 miles on it. I now have a 383
Old Mar 22, 2008 | 12:10 AM
m6ttop's Avatar
ouch!!!!
Old Mar 22, 2008 | 11:55 AM
Moderator
I'm always worried my nozzle will come apart and do similar damage.
Old Mar 22, 2008 | 12:25 PM
blk97z28's Avatar
I was putting on a STB nut and it fell lucky I checked at around on the k-member and everything and can't find it so I don't think I should have any problems. I would get that bolt out of there man.
