blowby
Old Mar 21, 2008 | 11:30 AM
stealthws6's Avatar
Default blowby
I just got done driving about 1000 miles on my new 383 lt1. It is a 11.5 to 1 383 forged internals and perfect circle rings. The problem im having is that at idle or even driving it i have steam coming out of my catch can. I made my own catch can with a line coming off each valve cover to help relieve the pressure and to avoid this. Should i be worried or is this common. Also im running your standard dino oil. Any help would be great.
Old Mar 22, 2008 | 05:19 PM
mtperformance's Avatar
Are you getting any oil in the catch can , does your oil get dark and gassy?
Old Mar 24, 2008 | 08:39 AM
stealthws6's Avatar
Im not getting any oil in the catch can. It just seems to be steam which causes some moisture to biuld in the can. I think that part of the reason for the moisture is that it is in the 20's and 30's here where i live and with that can getting hot and cold it causes a little condensation. Im getting ready to do a compression check and a leak down test to see if i can find anything there. It just seems that my rings should have seated by now.
Old Mar 25, 2008 | 01:40 AM
I dont think you have anything to worry about ,but I know where you are coming from.
Old Mar 25, 2008 | 05:46 AM
stealthws6's Avatar
Im probably worring about nothing but motors arent cheap and your on egg shells for awhile after you get a new motor together.
Old Mar 26, 2008 | 12:38 AM
1995ta383's Avatar
mine does the same in the cold
Old Mar 26, 2008 | 03:43 AM
I do the same thing .
