94 Trans am won't start
Old Mar 22, 2008 | 04:51 PM
formulajunky's Avatar
Default 94 Trans am won't start
OK guys i just brought this 1994 trans am and the last owner said starter was bad, So i took out the starter took it to napa had it tested works fine. Came home and tried it nothing, I HAVE power inside car lights and such. I can get spark on top of the starter... I was told the lil wire is the ign wire. to put a test light on it.. Well i did nothing. I get no sound out of the start whats so ever. Any other idea guys. I'm out right now with a wire tester going over everything i can find. Any tips
Old Mar 22, 2008 | 05:46 PM
9formula4's Avatar
are the wires on there correctly? make sure the grounds are correct.
Old Mar 23, 2008 | 03:23 PM
OK update, I brought a new starter nothing, Only sound it makes is a clicking under the Dash, Any ideas what this could be. I looked around i can't tell where it is coming from, Car has a Alarm system and i think once had a Remote starter on it. So there are alot of wires down there, Please any tips would help
Old Mar 23, 2008 | 05:14 PM
B4CZR2's Avatar
check the starter and make sure those wires are on correctly, I had a funky starter that had 3 places I could install the hot and ground, needless to say after doing tons of work that day with the headers and not having it turn over was a real bitch! If your only hearing a clicking in the dash it could be the issue, but when mine wasn't turning over it didn't make any noise at all. not sure what that clicking could be.
Old Mar 23, 2008 | 06:46 PM
Yeah and The Ecm? ing Fuse keeps blowing.. So that must mean that i have a hot wire grounding somewhere..but where i'm getting pissed off
