tps and tb ?
Old Mar 22, 2008 | 06:17 PM
andrew ws6's Avatar
Default tps and tb ?
i bought a used 52 mm holley tb with the sensors on it and put it on last night and driving it around today it through a tps code and would not downshift so i cleared and drove it home so my ? is would the tps need adjusting to my car if so how do you adjust it and what do you need to do it, it also idles a little higher than normal (1200-1300range)
Old Mar 23, 2008 | 10:27 AM
FlamingChicken's Avatar
the high idle could also be a leak but you should have an idle screw by the cables that you can adjust. also remember reading some tb's you have to adjust the tps or slot it. try searching that, my mind is not all here.
