OptiSpark vent install on new elbow.
Old Mar 23, 2008 | 01:23 PM
Bowtie Boy's Avatar
Default OptiSpark vent install on new elbow.
I have to replace my stock elbow, its starting to dry rot. When I install it does it matter where I put the vent? The elbow I am getting is a black powder coated one from CRT, new for like 55 shipped and it has the two rubber sleeves for the maf and the TB could I just poke a hole in one of the rubber sleeves (after maf or before TB...does it matter?) with a nail or something and stick it in there or does it have to be in a specific spot?
Old Mar 23, 2008 | 08:51 PM
Bowtie Boy's Avatar
bumpy bump bump bump would like to know
Old Mar 23, 2008 | 08:52 PM
porksoda's Avatar
They usually come with a grommet so you can drill into the elbow, put the grommet into the hole, and then the vent into the grommet.
Old Mar 23, 2008 | 09:11 PM
blk97z28's Avatar
hey porksoda I am to order a crome/ceramic one for my LT1 can you pm somewhere I could get one that has the hole drilled/the gromment so I can just put the vent into the drilled hole with the gromment.
Old Mar 23, 2008 | 09:23 PM
porksoda's Avatar
Alot of the companies come with everything to connect the vent including grommets. BUT they are usually not pre-drilled because of the fact that people with earlier LT1's that don't have the venting option don't need the hole. You would only have to drill a small hole anyway then the grommet just pops in.
