pushrod length
Old Mar 24, 2008 | 08:56 AM
VendettaV6's Avatar
Default pushrod length
Hi, Im going to be installing a cam soon and I think I should be using stock length pushrods...
The cam is a Cam Motions Custom Ground Camshaft
208/219 duration
.539/.541 lift
114 Lobe seperation
Crane Gold 1.6 Ratio Aluminum Self Aligning Roller Rockers
Comp Cams 918 Valve Springs with Matching Comp Retainers and Locks
GM Ls7 Lifters
With that setup will I use stock length or will any of the above effect the length?
I was told it would only change if the base circle of the cam was different or if I had the heads milled....
Old Mar 24, 2008 | 10:17 AM
StealthFormula's Avatar
Your gonna wanna stick with the stock length 7.2" Pushrods.
Old Mar 24, 2008 | 10:29 AM
VendettaV6's Avatar
thats what im hoping for kuz they are the cheapest!
Old Mar 24, 2008 | 11:08 AM
GreatWhiteZ28's Avatar
Hardend 7.2's....I got mine from thunder for around 50 bucks for the set...But I'm sure it doesn't really matter which ones you use as long as they are hardend
Old Mar 24, 2008 | 11:38 AM
VendettaV6's Avatar
kk, im ordering them right now...
38.50$ shipped....
Old Mar 24, 2008 | 01:14 PM
fordeater's Avatar
you should check for length, the ls7 lifters have a deeper pocket in them, the only way to know exactly what length you need is check. most likely you will just need 7.200's but i always check.
