who has had problems with msd opti??
Old Mar 25, 2008 | 04:05 PM
mean94lt1's Avatar
Default who has had problems with msd opti??
just wondering if anyone has had any problems with their msd opti?...i have a ignition problem and i believe it is the opti..i bought it used...as soon as there is a load on the motor above 2000 rpm it misses like crazy...and at an idle when you first start it it pops through the exhaust
Old Mar 25, 2008 | 04:49 PM
94nitrousedLT1's Avatar
I had a problem with my first one. I got it replaced and had no problems after that. Most of the problems with the MSD opti are that the rotor comes loose. You should check that first.
Old Mar 25, 2008 | 04:50 PM
mean94lt1's Avatar
i would think that if the rotor came loose it would miss all the time and it doesnt at an idle
Old Mar 25, 2008 | 11:17 PM
fordeater's Avatar
did you install it correctly, is car throwing any codes??
Old Mar 25, 2008 | 11:21 PM
Revelation Z28's Avatar
maybe carbon tracking?
Old Mar 25, 2008 | 11:42 PM
porksoda's Avatar
I have read about others having problems with them but most were due to improper installation. Mine has worked perfect since I installed it, and I open it up everyday that I drive!
Old Mar 26, 2008 | 03:15 AM
mean94lt1's Avatar
honestly there is really no wrong way to install the motor was on tdc #1 and i put the pin in its hole anything over 2000 rpm it misses like crazy im going to try a delco in it to see if it fixes it
Old Mar 26, 2008 | 07:56 AM
Green3spd's Avatar
PLEASE check the obvious FIRST! I installed a motor once and it started misfiring under a load. I replaced the opti also.
I had two plug wires swapped the whole time!
Might I add, the opti DID quit on me 10 mins. later driving down the road
(guessing the two being swapped messed it up)
Old Mar 26, 2008 | 08:04 AM
355z28's Avatar
ive had mine for ahwile and no issues.
Old Mar 26, 2008 | 09:05 AM
B4CZR2's Avatar
No problems with mine, bought mine as a complete unit new, never opened it up to make sure the rotor wasn't loose so hopefully it will continue to keep working perfectly.
Old Mar 26, 2008 | 11:29 AM
porksoda's Avatar
When I say improper installation I mean they assembled the opti wrong. The MSD opti has been known for the o-ring between the cap and housing to come loose and cause the rotor to rub. This is why they started putting out the square o-ring so it wouldn't roll off its lip.
Old Mar 26, 2008 | 11:52 AM
mean94lt1's Avatar
ic what your saying i had the cap off of it and couldt see anything wrong and called msd and the tech line sucks im not sure its the opti now i have a feeling its the lifters
