o2 extension's, home made
Old Apr 3, 2008 | 04:20 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default o2 extension's, home made
Alright when I did my motor swap I added lt's, so instead of buying extensions I extended the harness on the passenger side, and have no problems with it. but on the driverside I extended the harness right on the 02, instead of the harness, and that o2 is reading wack, but it is a bosch so I think its just bad. whose extended harnesses and had it work perfectly, and how did you do it, on the 02 or on the engine harness?
Old Apr 3, 2008 | 04:21 PM
Camaroholic's Avatar
Engine side of the harness is how I extended mine. Soldered and heat shrunk all wire splices. Zero problems.
But I ONLY use AC Delco sensors.
Old Apr 4, 2008 | 01:48 AM
m6ttop's Avatar
bump im curious also
