Ignition Break-up at High Rpms
On the way home, it starts doing it again.... Dont know what to do...
Take a look at my dyno graph and you can see how it gets fuzzy above 4k
Im actually in the middle of an Opti & water pump job right now, and while im at it i was going to change the plugs and wires... in addition, and now after reading this thread i was contemplating on a new coil too.. thoughts?
BTW what were your mods with those dyno numbers?
everything is fine untill you hit that, then it sputters, fuel cuts and dies.
soon as you start it back up.. everything is fine untill the next time.
it also takes longer to start then other LT's i have seen. which to means sounds like Ignition issue. However opti's usually just go out, everything works fine except for start-up, and the 3000 RPM die-out.
