Gear Lube?
Old Apr 7, 2008 | 03:55 PM
lilblackZ28's Avatar
Default Gear Lube?
What kind of gear lube should I get for my rear end?I am putting in 3.73s in it and I dont know what kind to put in it.Also do I need to pick a gasket up I know some guys just use silicone?Thanks
Old Apr 7, 2008 | 04:02 PM
Formula383's Avatar
I just use conventional Valvoline 80W-90. Don't forget the posi-additive. Ultra Gray RTV will work.
Old Apr 7, 2008 | 05:24 PM
Do I put that in all together or seperate?
Old Apr 7, 2008 | 05:26 PM
jb442's Avatar
You don't always need additive... It depends on the type of differential. I belive the Auburn/clutch-type requires the additive and the Torsen/worm-gear type do not. More info here: https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
Old Apr 7, 2008 | 05:59 PM
3DFORMULA's Avatar
Mobil 1 synthetic 75w-90
