rear end noise
Old Apr 8, 2008 | 05:22 PM
ROUDA's Avatar
Default rear end noise
when I brake rite before it stops complete I heard and feel something it pops or clicks 1 time. I got out of the car and pushing on the car up and down it doesnt make the noise when I rock the tire back and forth and push and pull it, makes the poping sound what could this be.
Old Apr 8, 2008 | 05:34 PM
IronOutlaw's Avatar
mine makes a popping noise whenever i accelerate hard. but i still havent found out what is doing it.
Old Apr 8, 2008 | 06:53 PM
ROUDA's Avatar
Id like to know what it is
Old Apr 8, 2008 | 07:07 PM
IronOutlaw's Avatar
me too. ive got under the car and cant see anything moving. but i have noticed that my tires are rubbing the inside of the fender wells some. ive also changed the fluid and it made no difference.
Old Apr 8, 2008 | 08:19 PM
ROUDA's Avatar
I checked to see if my tire was rubd its not but I can pull on the wheel and here the pop or if I move the wheel back in forth
Old Apr 8, 2008 | 10:43 PM
IronOutlaw's Avatar
have you checked to make sure the lug nuts are tight? the reason i ask is my old ford trucks front end was doing the same thing and i came to find out that i was about to lose my front right tire.
Old Apr 9, 2008 | 10:50 AM
ROUDA's Avatar
you know I will check that I had the tires off not to long ago.
Old Apr 9, 2008 | 11:19 AM
fordeater's Avatar
mine makes noise, but i deal with it. Its a 7.5 inch 10bolt, after a few hard launches it clicks when I drive It will blow up one of these day then I can get a 12 bolt.
Old Apr 10, 2008 | 02:04 PM
great421's Avatar
Default Ring and Pinion
My last rear end was "a little noisy" - and when DTS rebuilt the 10 bolt I got three loose teeth! It's fine now : )
Old Apr 10, 2008 | 02:10 PM
LT1MAN's Avatar
something is lose, check the wheels, then check the torque arm. based on the load being taken off the rear end when you come to a stop, sounds like it could be a loose torque arm or a loose wheel.
Old Apr 10, 2008 | 04:51 PM
ROUDA's Avatar
I jacked it up today because its getting to be worse the wheel is tight I put it in nutral and spin the tires cant make it happen shook it pulled on the wheels cant seem to find anything loose. Its like if im stoping or if Im braking and let off the brake I hear it like a bump or pop you know.
