Some Problems Help.
Old Apr 9, 2008 | 08:17 PM
cam2z's Avatar
Default Some Problems Help.
I am having a problem with my car missing at idle. When i start the car it idles ok and then in about 2-3 minutes it will smoke and after about 20 minutes it wont smoke anymore. I installed headers and deleted the cats, air and egr, but did not get a tune for the long tubes, will this cause my car to run liked that or run rich. I installed a new opti, plugs, wires, fuel filter, and ory pipe. So i dont know why it is poping at idle. It will also not idle by itself without me giving some gas. Dont know if i need a tune or what but i had the idileing problem before the headers but not the miss. Sorry for all the questions Thanks in advance.
Old Apr 9, 2008 | 08:38 PM
LS1_K1DD's Avatar
Are you plugs wires touching your headers and arching? If you installed L/T's and removed your O2's this may cause your car to run rich. And maybe your fuel pump is slowly pooping out on you.
