Electrical Problems?? I think?? Please help
Old Apr 15, 2008 | 05:54 PM
93z28_6spd's Avatar
Default Electrical Problems?? I think?? Please help
My 93 z28 is really got me Pi%$$^%. It started out running for about 2 to 3 min. and then it would die.. so i replaced the coil.(msd) then it did the same thing run, warm up then die.. so i replaced the fuel pump.(walbro 255) .. then it did the same thing, so i replaced the Ingnition control module..now it will run for about 5 to 10 min. then guess what it dies with no fire.. i have no idea what else it could be.. someone help
shayne
Old Apr 15, 2008 | 05:55 PM
Formula350's Avatar
The $8 fuel filter? Or $5 in gas to get it to the sender? >_>
Old Apr 15, 2008 | 05:59 PM
93z28_6spd's Avatar
Nope just changed that too with the new fuel pump...
any other ideas.. oh and new 93 octane fuel also
but no fire
anyone?
Old Apr 15, 2008 | 06:19 PM
Formula350's Avatar
Fuel Pump Relay? New Coil wire?
Old Apr 15, 2008 | 06:26 PM
93z28_6spd's Avatar
new msd wires.. and just a little bit ago i drove like 6 miles then it died and i immediatly checked my fuel pressure and it was like 42 or 45 when i turned the key on... so i dont think it has anything to do with the fuel... i put a tester on the plug wire and it had no fire...
Old Apr 15, 2008 | 08:08 PM
93z28_6spd's Avatar
ttt
help please
Old Apr 15, 2008 | 08:33 PM
brokenbird's Avatar
how old is the opti?
Old Apr 15, 2008 | 09:03 PM
Formula350's Avatar
LOL Since when has Opti's age mattered for it to take a ****?
If it's not a fuse, not a relay and not the ICM or Coil, then it's a good chance it's the Opti. I can't think of anything else. Make sure to try your old ICM and Coil JUST to cover all your bases.
Old Apr 16, 2008 | 08:47 AM
93z28_6spd's Avatar
well it the origional opti with about 176000 miles on it..but would it run like crap if the opti was bad... it runs awesome until it gets warm then no miss fires, it just dies. and then no spark..
Old Apr 16, 2008 | 11:37 AM
93z28_6spd's Avatar
ttt.
i need help
Old Apr 16, 2008 | 11:46 AM
Geneticallybroke's Avatar
Its the opti
Old Apr 16, 2008 | 03:02 PM
93z28_6spd's Avatar
but if it was the opti wouldn't run badly... just miss and stuff.. cause isant it just a rotor and points right... i was just thinking that it would miss out and just run like crap rather than run good and then just die
Old Apr 16, 2008 | 06:57 PM
93z28_6spd's Avatar
ttt
help
Old Apr 16, 2008 | 07:24 PM
Formula350's Avatar
If it was the opti, it would do a whole LIST of things. Including your problems.
You ask for help, people give you the 90% probably cause, you say No it's not it. You're not going to get help anymore.
So, replace the opti, since it'll need in in the next 10K miles ANYWAYS, and THEN tell us "no" or "thanks", capiche?
Old Apr 18, 2008 | 08:31 PM
93z28_6spd's Avatar
WOW... thats awesome,, i was just trying to cover any and all bases.. just trying to do a complete check and make sure before i spend money for nothing but i appreciate all the help.. and no one needs smart @$$ comments ...... capiche?
Old Apr 18, 2008 | 08:51 PM
Formula350's Avatar
You'll get smart assed comments, when something sounds quite like what the problem is, and the OP continually says "no, not the problem". We've had your type around here before, and if it's not me who says it, it'd have been someone else.
Old Apr 23, 2008 | 04:47 PM
93z28_6spd's Avatar
hey man i dont want any bad blood on here just wanting to be thorough and not spend money where i dont need...
Old Apr 23, 2008 | 05:41 PM
Formula350's Avatar
Well, I assume you're looking at pushing the R's on that motor, so even so, a new opti (if it isn't recently replaced) wouldn't be a bad investment anyways.
