Exhaust setup question
Old Apr 16, 2008 | 09:11 AM
1redta's Avatar
Default Exhaust setup question
I have a crapmaster catback with a dynomax bullet in the I-pipe for now. I am thinking about this. replacing the crossflow muffler with a hooker aerochamber, single in offset and center exit to the driver's side pipe. for the pass side I am thinking putting an electric cutout in the pipe right after it comes over the axle.. My thoughts are this, with the cutout closed the exhaust will run though the aerochamber being relatively quiet with the cut out open it will run through the dyno max bullet out the tip. Who else has done this and how did it work. Thanks Art
Old Apr 16, 2008 | 09:12 AM
Slowmaro95Z28's Avatar
Sounds like the Borla cat back to me.
Old Apr 16, 2008 | 09:15 AM
1redta's Avatar
Default re
I am trying to avoid the borla sound and price tag. Thanks
Old Apr 16, 2008 | 09:17 AM
What you just explained is basically exactly what Borla sells. That would give you close to the same sound as well. If you don't like that sound then try again. Just trying to save you from wasting time on something you won't be happy with.
