feul filter install
Old Apr 17, 2008 | 04:55 PM
Kmaroman's Avatar
Default feul filter install
hi there. I recently bought a new feul filter for my 93 z28. Shes been hesitating an i can't figure out quite why. So how hard is it to take off the old one an put the new one in. Run me through the steps if you can. Thank you
Old Apr 17, 2008 | 04:58 PM
RED94Z28's Avatar
its not to hard at all but ive never heard of an feul filter before lol
Old Apr 17, 2008 | 04:59 PM
chavez885's Avatar
You say its not hard and then say never heard of a fuel filter? Are you drunk?
http://shbox.com/1/fuel_filter.html It's very simple OP, doesn't take but 10 minutes.
Kmaroman's Avatar
my screw up. just wondered because i didnt think the o2 sensors would be hard to do that turned out a lil harder then i thought.
Old Apr 17, 2008 | 05:06 PM
CaribooLou's Avatar
I think he was commenting on the incorrect spelling of "fuel"
Old Apr 17, 2008 | 05:08 PM
chavez885's Avatar
It's not a spelling bee, no big deal. O2's are only difficult because the clips are a pain in the ***. Just follow the instructions on the link, you should have no problems.
Ah...guess i just ignored the typo
Old Apr 17, 2008 | 07:29 PM
Formula350's Avatar
Pass side O2 is the only hard one. Fuel Filter is a breeze unless it's rusted together.
Old Apr 18, 2008 | 10:17 AM
djjab57's Avatar
its simple jack up the rear a little and you will need a quick-connect separator and 2 cresent wrenches make sure you take off the fuel cap. as already stated maybe 10 min.
Old Apr 18, 2008 | 02:23 PM
the_merv's Avatar
It's infront of the Drivers side Rear Tire, up on the Body.. pretty easy. Bleed it first or it will squirt all over..
I assume you guys are talking about the O2's on Stock Manifolds.. with LT's they are cake..
Old Apr 18, 2008 | 02:47 PM
C5042081's Avatar
may need to spray some rust pen. on the threads to break nuts loose, a few years can make em hell to break loose.
Old Apr 18, 2008 | 02:52 PM
djjab57's Avatar
If you take the gas cap off to release the pressure it will keep the spilling to a min.
Old Apr 18, 2008 | 03:07 PM
the_merv's Avatar
Not with the built up pressure in the Lines..
Old Apr 18, 2008 | 03:17 PM
djjab57's Avatar
For me the first time i ever did the job i took the filter off without taking off the cap and the gas just kept coming i later learned to take the cap off yes some still flows out but just whats in the line If there is pressure in the tank it will keep pushing it throuh the line
Old Apr 18, 2008 | 04:03 PM
Formula350's Avatar
HAH Mine doesn't use quick connects (I don't think). Either that, or I just took it off by hand heh
Old Apr 18, 2008 | 04:43 PM
Toronto_LT1's Avatar
i'm about to do mine too...thanks for the tips and suggestions,guys.
