installed new battery box and car is dying
Old Apr 23, 2008 | 08:01 PM
97lt1z28's Avatar
Default installed new battery box and car is dying
i installed summits battery box and a cut off switch and now the car is not charging. I ran the ground in to the inside hatch and sanded away all paint so i know i have a good ground i then have a power wire coming from the starter to the battery. I also have a ten gauge wire coming from my alternator that is also attatched to the positive post in the battery.> i have it wired so that when i "kill" the battery it also kills the power to the alternator that way if something bad happens at the track and they kill the car it really dies and does not continue to run of the alt. So anyways the car starts with 13-14 volts and holds but when i start to drive it starts bleeding down and then just turns off. I replaced the alternator and battery and am 100% that they are ok. Do you think the 10 gausge wire is not enough to support charge from the alt to the battery? any suggestions would be great from other guys running similar set ups.
