Curious about possible roller rocker noise
Old Apr 23, 2008 | 08:58 PM
Ironxcross's Avatar
Default Curious about possible roller rocker noise
I have the steel 1.6 crane rockers with polylocks. When I put them on, I adjusted them near a half turn after valve lash. I think they're the culprit as to way my car is making alot of noise. Any ideas?
Old Apr 23, 2008 | 11:13 PM
sweet-94z28's Avatar
RR are very noisy. If you sound like a sewing machine, you are fine.
Old Apr 24, 2008 | 04:22 AM
Black96Z's Avatar
i see that you don't have a LT4 KM listed in your sig. I would recammend that you get a a LT4 KM because with roller rockers the stock KM can detect false knock and can cause your timing to retard a few degrees. the LT4 KM is less sensetive.
Old Apr 24, 2008 | 07:13 AM
355z28's Avatar
mine are super noisy, almost embarrassing. Ive had them readjusted so manytimes and it still sounds like i have a couple sticky lifters. Hell i even replaced the lifters lol. My car runs really shitty up top.
I figured my tune would desensitive the knock sensor so im not running the lt4 KM is this correct???
Old Apr 24, 2008 | 09:09 AM
Ironxcross's Avatar
I got the LT4 KM, I did just forget to list that, haha. My car runs like a top, its just a noisy sob. I guess I'm normal then, haha.
Yep, definitely a sewing machine.
Old Apr 24, 2008 | 10:54 AM
Ironxcross's Avatar
although now im a little confused, because my one friend said that rrs are supposed to be quiet.
Old Apr 24, 2008 | 10:56 AM
You are fine then. Many guys that install the Hotcam kit make the RR noise their first complaint, but all the ones that I have heard (at least the ones done right) have that distinct sound to them.
Old Apr 24, 2008 | 11:27 AM
355z28's Avatar
id honestly have to hear some ones in person, because mine is really loud. My buddy has 1.5's on his 85 transam and you can barely here them.
He also is running some decently thick edelbrock tall valve covers, maybe thats why his is so quiet.
Im thinking about just buying a set of Composite, or magnesium vette valve covers and seeing what happens.
Old Apr 24, 2008 | 11:31 AM
Ironxcross's Avatar
I'm running modified stock valve covers. I could see how noise would travel through them much easier.
Old Apr 24, 2008 | 11:44 AM
355z28's Avatar
Thats kind of what i meant, there basically tin VC's with the aluminum heads and tin VC's it has to magnified a bit..
Old Apr 24, 2008 | 11:49 AM
Ironxcross's Avatar
Well this makes me feel much better. I knew everything I did was well adjusted and done properly, but yet it still sounded like a strange weak exhaust leak/valve chatter noise when throttle was added under moderate load. This seems like the cause in most respects.
