The famous Optispark
Old Apr 23, 2008 | 10:30 PM
BLt196ta's Avatar
Default The famous Optispark
Whats up everyone, I just wanted to know if there is anyway to get rid of this and get something like the LS1 cars have so its not so damn hard to do a tune up. If there is such a thing, how much does it cost and where can I find it.
Old Apr 23, 2008 | 10:33 PM
SlowZ28/SS's Avatar
Hey man. Do a search on optis and i'm sure you'll find more than enough info to cover this for you. There is a conversion though to put coils on like the LS engines but i dont know where you get it......but if you search you might turn something up.
Old Apr 23, 2008 | 10:38 PM
LT1's Avatar
LT1
Theres two types of system that i know of, i heard the LTCC is better.
http://www.bailey-eng.com/LTCC.html You can use the LS1 coils with this.
http://www.delteq.com/default.htm
Old Apr 23, 2008 | 10:58 PM
BLt196ta's Avatar
Thanks guys that helps a lot, it's kind of expensive though with the Ls1 coil packs and so-on, I dont know if it would be worth it.
Old Apr 23, 2008 | 11:16 PM
sweet-94z28's Avatar
I have the Delteq. It is a great system and overall I am pleased with it. I bought my kit used (guy claimed it was new but it definitely was not) and no problems so far. It idles and revs more like an LS1 with this kit on it.
Old Apr 23, 2008 | 11:30 PM
BLt196ta's Avatar
Really I wonder why, do you have any pictures of your set up, I would like to see the different looks of set-ups.
Old Apr 23, 2008 | 11:35 PM
Mine is on the Driver Side Valve cover
The pic is a bit blurry but you can see what it looks like. I had to replace one coil on it because one the guy sent me was corroded. It runs like a champ with this thing.
Old Apr 24, 2008 | 12:11 AM
BLt196ta's Avatar
Is it hard to position the wires to where they don't get touched by the exhaust manifold/headers, or do you use head wrap or anything with it?
Old Apr 24, 2008 | 12:20 AM
You can run them through the stock location, but I snaked mine around kinda nicely and they do not touch anywhere. I could get some more pics up tomorrow night.
Old Apr 24, 2008 | 12:26 AM
Cross's Avatar
How long did it take you? I am def looking for one as I am just waiting for the day opti fails... Yeah better to get it now then later.
Old Apr 24, 2008 | 12:30 AM
To install the kit, it took about 2 hours for everything, but I am a mechanic so I might be a bit faster than some.
Old Apr 24, 2008 | 12:35 AM
BLt196ta's Avatar
Ya man it looks like you have a pretty nice setup, but definately post pictures up tomorrow night, I def. want to see some more pictures of yours
Old Apr 24, 2008 | 05:10 AM
96capricemgr's Avatar
The designer of Delteq is ill and guys are having issues with it and since the guy is ill there is NO support or replacement parts or even new kits to be had.
BOTH systems require a functional opti base meaning if one of these "fixes" your car then all you needed was a $100-150 cap and rotor kit, not a $600 "opti eliminator" kit that keeps the opti.
A cap and rotor are wear items on any distributor and for some reason people don't seem to grasp that with the LT1 and when they wear out curse the opti.
Old Apr 24, 2008 | 05:46 AM
LT1-DAN's Avatar
X2 The opti is really pretty good, not many other distributors can last as long as the opti can. The biggest concern with the opti is the place where it's located, that is what makes it a pita sometimes. Other than getting it wet, the opti really has no other issues.
Old Apr 24, 2008 | 06:06 AM
I honestly just got it because I knew the cap and rotor would dick up on me sooner than later. When i had the miss, that was enough. Parts really are not that hard to get. ACDelco sells everything but the opti box and the harnesses. I called JT not all that long ago because I needed a heat shield that was not included. They have had excellent service and support in my experience.
Old Apr 24, 2008 | 07:32 AM
DAVE00's Avatar
Hey I have the Delteq setup on mine as well and have loved it for the past 3 years. The install is real easy and the power/response is way better than stock. Here's a pic of mine installed as well as you can go with the MSD coils as I did and I heat shielded each wire and routed them around the headers to keep them from getting burnt as this was my major problem before the Delteq. Just make sure you know that they are correct as JC the guy with Delteq is sick right now and customer service is next to impossible. The future of his company is uncertain as of now. That being said I still love the delteq setup and would highly recc it anyday.
Pic:
Old Apr 24, 2008 | 10:05 AM
LT1-DAN's Avatar
Pic:
WOW!!: That is one awesome clean engine!!!!
Old Apr 24, 2008 | 10:09 AM
DAVE00's Avatar
Thanks I'm trying to keep her clean these days as not too many miles are put on the clock anymore - just my weekend toy.
Old Apr 24, 2008 | 10:16 AM
BattleShip's Avatar
Sorry to hear he is sick. I wondered emailed a while back and never got a reply.
The Delteq system is great I have it on two boosted LT1's and it is a life saver. It cleans up most rough idles and pulls smoother than stock. Have not compared to other system from what I hear it is also great system.
ONLY problem I have is when you do have a problem the waste fire can mask some fuel issues...
As for wires I used the Accel ~$35 and they modified nicely
Old Apr 24, 2008 | 10:42 AM
Where did you get these wires? I wanna get new ones because one of mine has a little bit of damage.
