Some 383 Questions
I use 6" rods.
You do not need a ATI balancer, stock is fine. If you do go "internal" balance just knock the weight off the flex plate or have the flywheel "neutral" balanced at a machine shop.
Many run a 847 on strocker motors. Any cam needs to be checked for clearance on stroker motors. some MINOR clearanceing may be required on cam.
The block will need to be cleared for the 383 strocker. You should be able to take your block and desired rotateing assembly to a machine shop for this machine work and have the rotating assembly "neutral" balanced.
Only real reason to go with 6" rods is they allow for a lighter piston and since rod/bolts almost always fail under tension trying to pull the piston back down after TDC lightening these parts results in substantially less tension on the rod and rod bolts improving reliability.
I am not saying rod length has no impact on power or whatever just saying for a street/strip motor discussing such things is pointless, if there is a difference it is not big enough to bother using to justify the change in plans.
